Audio Playback Issues on Samsung TVs (2020–2022 Models)
We are playing HLS video contents, video and audio both working fine on 2018 & 2023 model Samsung TV. On 2020, 2021 and 2022 model Samsung TVs, video is playing but audio is NOT working. Not able to see any error in console related to the player or audio.
  1. Are these codecs supported?
  2. Is the config correct? Or do we need to add or remove something?
  3. Any other recommended solution.
Please help.
CODECS=“avc1.4D401F,mp4a.40.2”
CODECS=“avc1.640029,mp4a.40.2”
CODECS=“avc1.4D401E,mp4a.40.2”
CODECS=“avc1.42C015,mp4a.40.2”
config.xml**
<?xml version=*"1.0"* encoding=*"UTF-8"*?>
<widget xmlns:tizen=http://tizen.org/ns/widgets xmlns="Widgets Namespace" id="http://yourdomain/TEST” version=“1.0.0” viewmodes=“maximized”>
<access origin=*"\*"* subdomains=*"true"*></access>
<tizen:app-control>
    <tizen:src name=*"index.html"* reload=*"disable"*/>
    <tizen:operation name=*"[http://samsung.com/appcontrol/operation/eden_resume](http://samsung.com/appcontrol/operation/eden_resume)"*/>
</tizen:app-control>
<tizen:application id=*"DUK1XWHusE.TEST”* package=*"DUK1XWHusE"* required_version=*"2.3"*/>
<content src=*"index.html"*/>
<feature name=*"[http://tizen.org/feature/screen.size.normal.1080.1920](http://tizen.org/feature/screen.size.normal.1080.1920)"*/>
<icon src=*"icon.png"*/>
<tizen:metadata key=*"*[Check out our new 2025 TVs featuring OLED, 8K, and AI! | Samsung US](http://samsung.com/tv/metadata/devel.api.version)*"* value=*"2.4"*/>
<name>Test</name>
<tizen:privilege name=*"[http://developer.samsung.com/privilege/player.partner](http://developer.samsung.com/privilege/player.partner)"*/>
<tizen:privilege name=*"[http://tizen.org/privilege/tv.audio](http://tizen.org/privilege/tv.audio)"*/>
<tizen:privilege name=*"[http://developer.samsung.com/privilege/drmplay](http://developer.samsung.com/privilege/drmplay)"*/>
<tizen:privilege name=*"[http://developer.samsung.com/privilege/drminfo](http://developer.samsung.com/privilege/drminfo)"*/>
<tizen:privilege name=*"[http://developer.samsung.com/privilege/network.public](http://developer.samsung.com/privilege/network.public)"*/>
<tizen:privilege name=*"[http://tizen.org/privilege/internet](http://tizen.org/privilege/internet)"*/>
<tizen:privilege name=*"[http://tizen.org/privilege/tv.inputdevice](http://tizen.org/privilege/tv.inputdevice)"*/>
<tizen:privilege name=*"[http://tizen.org/privilege/tv.window](http://tizen.org/privilege/tv.window)"*/>
<tizen:privilege name=*"[http://tizen.org/privilege/system](http://tizen.org/privilege/system)"*/>
<tizen:privilege name=*"*[Samsung Developer](http://developer.samsung.com/privilege/productinfo)*"*/>
<tizen:privilege name=*"*[Samsung Developer](http://developer.samsung.com/privilege/adinfo)*"*/>
<tizen:profile name=*"tv-samsung"*/>
<tizen:setting screen-orientation=*"landscape"* context-menu=*"enable"* background-support=*"disable"* encryption=*"disable"* install-location=*"auto"* hwkey-event=*"enable"*/>
Thanks
Hello & Welcome to Samsung Developer Forum
For Smart TV questions, please log in to TV Seller Office: (Seller2.0), go to the 1:1 Q&A section, and ask a question. Thank you.
