I can’t figure out why a formula is not working. If it’s January 19, and I have this formula:
([MON]==1?[DAY_1_31]:“Jan”)
It outputs 19. If it’s Feb, then it outputs “Jan”. (This is the correct behavior)
However, in instead I use this formula:
([MON]==1?“Jan” [DAY_1_31]:“Jan”)
It prints out the formula instead of “Jan 19”. I have played around with different syntax such as:
([MON]==1?[MON_S] [DAY_1_31]:“Jan”)
But none of these work. How can I get the formula to output the “Month Date” (Jan 19 for example) when it’s January, but only “Jan” if it’s any other month?
A solution suddenly came to me. Since in both True and False conditions, I want “Jan” to appear when it’s January or any other month, I can do this:
Jan ([MON]==1?[DAY_1_31]:“”)
This prints “Jan” first and then if it is the month of January, will also include the date, but if it’s another month, it will not. This is exactly what I want.
I may have spoken too soon. It works for January as mentioned above, but when the month is Feb, I thought I could do this:
Feb ([MON]==2?[DAY_1_31]:“”)
But again it outputs the formula instead of displaying Feb followed by the date. January worked fine so I’m not sure what’s up with Feb or Mar, which I also tried.
Seems that there was something wrong with the double-quotes at the end when I copied Jan to Feb. Once I retyped the double-quotes, it worked as expected. Still not sure why Jan worked but looking at what I pasted above, it seems this site prints smart quotes rather than straight quotes, even though that’s what I’m pasting below.
I was able to make the change and it’s working fine now.
LOL
It was a nice talk with yourself!
There is a problem with quotes, I still don’t get the difference.
But I’m glad you made it work!
Sometimes you just have to talk it out, even if nobody is listening. It’s surprising how well that works.
Note that the patient is using smart quotes.
