Hi,
I want to identify Dolby atmos and surround sound 5.1 capability on Samsung TV using tizen web api. Is there any way to identify it?
Thanks
Hi,
Thanks
Hi,
Did you ever find a way to check for Dolby Atmos support?
I have exactly the same question.
I have a 2022 The Frame TV which supports Dolby Atmos and has a toggle in the Audio Menu (Expert Settings) where you can turn Dolby Atmos on and off.
How can you know if a TV supports Dolby Atmos and if it is turned on or off?
This is an API for checking for supported Audio Format, but it lacks Dolby Atmos (but you can check for “E-AC3” which is compatible)
