Dear community,
I have developed a Tizen Wearable web application that has been on the store for some years now and passed countless updates / store reviews without any problems.
Some weeks ago, I finished the latest update (no major changes, especially not regarding configs) which works on my watches®, however, not for the support team which refuses to push the much needed update.
Since I cannot reproduce the error, I have no idea how to fix it. It even works when installing it via the beta channel. To me it seems there is an issue with the certificate, as the following message appears in the logs the support team sent me:
10-08 14:21:32.900+0700 4394 4394 W CERT_SVC: WrtSignatureValidator.cpp: check(522) > e[38;5;202;1mInvalid package - file hash value is difference.e[0m
10-08 14:21:32.900+0700 4394 4394 W WRT_INSTALLER: task_certify.cpp: throwCertificateInvalidException(373) > e[38;5;202;1mCertificate is Invalid [-31]e[0m
10-08 14:21:32.900+0700 4394 4394 E WRT_INSTALLER: task_certify.cpp: stepSignature(350) > e[38;5;160;1mError occured in signature validator: 79e[0m
10-08 14:21:32.970+0700 4394 4394 E APP2EXT : job_widget_install.cpp: SendFinishedFailure(412) > e[38;5;160;1me[38;5;160;1mError number: 79e[0me[0m
10-08 14:21:32.970+0700 4394 4394 E APP2EXT : job_widget_install.cpp: SendFinishedFailure(413) > e[38;5;160;1me[38;5;160;1mMessage: Invalid signature. Signed with wrong key, changed signature file or changed package filee[0me[0m
10-08 14:21:32.970+0700 4394 4394 W WRT_INSTALLER: pkgmgr_signal.cpp: sendSignal(275) > e[38;5;202;1mSuccess to send pkgmgr signal: error - 79:Invalid signature. Signed with wrong key, changed signature file or changed package filee[0m
I have re-registered the app four times now, reinstalled Tizen Studio, renewed all certificates but the application will just not work on the support team’s watch.
I’m looking forward to any advice you can give.
Thanks!
Best,
Tobias
