Font problem
Thanks Peter . I did wonder if a Build Would strip them out . I have not done that for a While , I will give it a go .
I had the same issue and tried installing the fonts on Windows. Tried unzipping, adding the fonts and rezipping with the same results.
Finally found that if you remove the use of all the fonts you can delete them and the add them again.
