"Get add-ons" greyed out fix
Hey guys I’m running Samsung internet browser on a Galaxy S9+ And when I try to use the get more add-on option in the settings, It is greyed out, and I cannot click it. I’ve searched and searched to no avail. Does anyone knoe how to fix this? Oh and I forgot to mention that I’m using the most recent version update. Thanks in advance for your time and any help or fixes! Cheers! :sweat_smile: :slightly_smiling_face:
Hello,
Thank you for participating in the Samsung Developer Forum. However, this is not the correct forum for consumer product bug reports, questions, or concerns. This forum is for third-party developer issues.
I would recommend one of the following:
  • Use the Samsung Members app for feedback
    or
  • Go to https://www.samsung.com and, depending on your location, either
    • Click Support → Community (under Product Support)
      or
    • Scroll all the way down to the bottom of the page and, under Support, click Samsung Community
Because end-user questions disrupt developer discussion, this thread will be removed soon.
