How do I get the location (lat and long) on webapp?
Ps.: navigator.geolocation throws error… and I didnt find any doc about the GPS itself…
Thank you for your time!
Actually, it not works for me too. I have tried to ask permission too. below is the code for ask location permissions. it enabled but still gives me a location unavailable error.
You need to add the below privilege to the config file using the privileges tab first.
http://tizen.org/privilege/location
Then handle your permission ask flow as below.
// use to ask permission for the location
function findLocation(askPermission) {
var permisson_status = tizen.ppm.checkPermission("http://tizen.org/privilege/location");
if (askPermission && permisson_status === 'PPM_ASK') {
tizen.ppm.requestPermission("http://tizen.org/privilege/location", function(e) {
if (e === 'PPM_DENY_ONCE') {
} else if (e === 'PPM_ALLOW_FOREVER') {
return callGeoLocationService();
} else if (permisson_status === 'PPM_ALLOW') {
// call geolocation service
function callGeoLocationService() {
if (navigator.geolocation) {
navigator.geolocation.getCurrentPosition(
locationSuccessCallback, locationErrorCallback,{enableHighAccuracy: true,maximumAge: 0,timeout: 10000}
} else {
console.log('Geolocation is not supported.');
// when process success
function locationSuccessCallback(position) {
console.log([position.coords.latitude,position.coords.longitude]);
// when process error
function locationErrorCallback(error) {
switch (error.code) {
case error.PERMISSION_DENIED:
console.log('User denied the request for Geolocation.');
break;
case error.POSITION_UNAVAILABLE:
console.log('Location information is unavailable.');
break;
case error.TIMEOUT:
console.log('The request to get user location timed out.');
break;
case error.UNKNOWN_ERROR:
console.log('An unknown error occurred.');
break;
but unfortunately, my issue was not resolved to enable permissions too. and then I tried to manually enable location permissions from watch settings. not success. hope you will find an answer!
Hello, I already solved this problem using the tizen “healthinfo” API.
Thank you!
can you please provide a link of it?
Thank you very much for the support!
You can use Tizen Human Activity Monitor (HAM) API or W3C Geolocation API
https://docs.tizen.org/application/web/guides/sensors/ham/
https://docs.tizen.org/application/web/guides/w3c/location/geolocation/
For both cases, please make sure location privilege is added on config.xml.
