I think this is how HR works. BTW, TicWatch 3 hasn’t been updated to Wear OS 3.0 yet, right?
Correct, not yet updated to wear os 3.0, maybe that’s it.
If I have time later, I will try again with a continous HR messurement to see if it works.
Does anyone know what is the AppID of the app that measures the heart rate?
It would be to put, that it opened in one touch, because reading the beat when clicking, it’s buggy.
Hi Matteo,
This issue has been fixed by WFS dev team and
this fix will be released in the next version of WFS.
Regards,
Jakia Sultana
Great news, thank you!
Hi Matteo.
Have you tried the Galaxy Watch Studio Converter software?
If you convert a sphere of yours, you will see that the heart rate measurement is correct and by tapping the application will speak.
Did this work for you?
Hi Sergio,
I only converted 2 watches with GWS Converter. Heart rate works better but these watch faces will only be compatible with Samsung GW4 (no third party devices) and you can’t get all the other customization features.
Hello,
My watch faces were rejected by Google due to the heart rate sensor is not working. They changed publish status as reject. What can I do? Will we have to wait for a new version for WFS? Will we not design till coming the new WFS? Is there a solution at least temporarily?
Thank you so much for your interest.
Sincerely,
Cem Erman
Hi Cem,
An update to WFS is coming which has a fix for this heartrate issue
Sometimes the [HR_IS_MEASURING] tag gets stuck in position 1 (ON) for a long time and does not show heart rate.
But I suspect the reason it was rejected is that heartrate does not work unless it is worn and manually triggered. Can you add comments to the reviewer like you can in Samsung Seller Portal?
Ron
Samsung Developer Relations
Hi Ron,
I have uploaded it 2 days ago. Unfortunately, there are no users for them Tomorrow I will post with promotion on Facebook groups. I hope, I will win users
The first time they published it but the message came from Google today and their message is below.
Publishing status: Rejected
- For example, your application watch face heart rate sensor isn’t working, even after waiting, it still did not read heart rate.
Sincerely,
Cem Erman
I think that is the bug that is fixed. The [HR_IS_MEASURING] is not working right and the after a bit the heartrate does not show.
But it could also be the reviewer does not wear a device but testing on a brick. so it doesn’t show any heartbeat.
Ron
Do you know when the new version of WFS will be published?
Yes, when new version will be released ? Hope that new version will add some new functions, like distance, speed, calories burned, altitude(actual and max), total ascend.
I have to get pedantic about the term “new version” it took Galaxy Watch Designer over 3 years to have a “New Version”.
There will be an update released soon.
Ron
Ron
The philosophy of WearOS development is that the user opens the apps not that the content is on a watch face.
Ron
Hello Ron, thank you so much for your interest.
I have a new problem. This time, Google reject my other watch face due to the buttons are not working. I tested on the emulator and I couldn’t see any problem. I have Samsung Galaxy S3 Classic. Unfortunately, I don’t have Watch 4. Samsung smartwatches are so expensive in Turkey this is why for now I can only test them on Emulator. Is there a suggestion? Thank you so much for your support.
PS: I realized that there are a lot of devices in the device catalogue on Play Store. I removed all of them except the Samsung Watch 4. I was using import GWD resource on Watch face Studio. This time, I added heart rate manually on my watch face and uploaded the new version on Play Store. I will inform you after the review.
Sincerely,
Cem Erman
I thought that might have been the issue a lot of sellers that converted .tpk to .aab missed that only GW4 was compatible.
There have been several reports of Heartrate not working correctly in WFS but I haven’t seen it in the converted GWS watchfaces.
Ron
The update was published Sep 16, 2021
Ron
Hi Ron,
Thank you so much for your interest and support.
Sincerely,
Cem Erman
