Hello,
is there a way to control the speed of animation/gif/webp?
What I want to do is to control the speed of heartbeat .gif,
for example if HR<80 then animation speed is slower
if HR>80 then animation speed is faster
and so on.
I cannot find a way to do it.
Is there some trick I’m missing?
Sorry I would have seen this before but the notifications on my Laptop are not working properly and new Topics are being pushed down the list . No you can not change the Frame rate of the Animations . It is fixed at 15FPS I believe . You can double frame stuff to choreograph it but can not change the run time . You will have to make your HR animation Live action . I have Formulas for zooming an image but you may like to have a go yourself.
masterboyhr.wfs.zip (178.6 KB)
Hi, would something like this work?
Have a look at the Zoomer .
HEART_RATE_ZOOMING_TEST.wfs.ZIP (282.9 KB)
Mayalona thank you, that works, I’m using that method.
Prearranged .gifs with different speeds.
I came from Facer, Facer has nice option for controling the speed of gifs inside the software, duration/speed can be set from 0 to anything.
So I was wondering if WFS has the same or similar option that I don’t know about.
russellcresser thank you, that works for images. Nice.
If it is a Trace you are after I have a couple of nice tests . I am not sure but you might be able to import short MP4 , Pre Timed . You might be able to import a a Gif with a Different frame rate . I have not tested all that . I am more keen on Stop Frame . You must also look at Putting Images in a Bit mapped font and then you can choreography the Text/Numerals at will .
Hi You could use 3 identical .gifs, but with 3 different speeds and insert them all in the same position and then control the display with the opacity from 0 to 100 depending on the pulsations
Try to see if this works well.
It works, thank you.
In fact the question was can the speed be changed inside WFS, after uploading gifs.
