Is there any API through I can get family Hub temperature?
You can access your device via the cloud api and get the temperature value over the temperaureMeasurement capability.
Checkout this doc: https://smartthings.developer.samsung.com/docs/api-ref/capabilities.html
Original thread is HERE
Sixerr
5
With Fridge Manager, you can quickly and easily the temperature of the Fridge/Freezer/Flex Zone section on your Family Hub.
- From the Home screen, swipe to the right for more options.
- Tap on the ‘Fridge Manager’ tile.
- The temperature of each zone will appear on the display. …
- Tap on ‘Save’ to save your preferences.
[Edit removed bad link]
