How to know how far apart each Index should be
Hi everybody,
I am new to making Watch Faces. I would like to know how far apart each index should be. You know the lines that go all the way around the watch?
Thanks
Jase
Nevermind :stuck_out_tongue: I figured it out.
Incase anybody else needs to know, all you need to do is add an Index from the Component menu, select an image, select it on the canvas, go to Properties on the right of the window and edit the INDEX SETTING properties.
