How to Retrieve Distance Data from Samsung Smart Tag 2 on Android (Usi
Hello,
I am currently working on a project to integrate Samsung Smart Tag 2 with an Android device.
The primary goal is to use UWB (Ultra-Wideband) technology to fetch accurate distance data from the Smart Tag 2.
What I’ve Found and Tried So Far:
  1. Utilizing UWB Technology:
  • Samsung Smart Tag 2 uses UWB for precise distance measurement.
  • I’ve learned that accessing UWB data might require an SDK or specific APIs provided by Samsung, but I’m struggling to locate the necessary documentation.
  1. Exploring SmartThings API:
  • I’ve reviewed the SmartThings API for managing Locations and Devices, but I couldn’t find any endpoints that directly provide distance data from the Smart Tag 2.
Assistance I’m Looking For:
  1. Accessing UWB Data:
  • Are there any Samsung-provided SDKs or libraries for working with UWB, specifically to retrieve distance data from the Smart Tag 2 on Android?
  1. Using SmartThings API:
  • Has anyone successfully used the SmartThings API to fetch data from a Samsung Smart Tag? If so, could you share guidance or examples?
Additional Questions:
  • Are there any Samsung developer forums or other resources where I can find detailed documentation or support for this?
  • If anyone has worked on a similar project, I’d greatly appreciate hearing about your experiences or any sample code you could share.
Thank you for your time and support!
Hello
Reach the Smart things community for your query related to Samsung Smart Tag 2.
