Smart Tag+ UWB Connection
I own a S22+ & Samsung Smart Tag+ . I will use the UWB connection in my own app. For that I need some parameters (ranging parameter) from the tag like Sessionkey,UwbAddress as described here:
Are there any documentation or API how to get this parameters to connect to the tag and get the UWB distance ? I don’t want to connect to the smart things cloud or similiar only the current distance to the tag if it is in range.
As far as I know Samsung does not offer any such API for UWB. Did you try any other SDK?
Which SDK should I try ?
