[HR] Circular Progress Bar not working with TicWatch Pro 5 Enduro
Hi there!
I’ve a problem with [HR] “tag value” not working if used in a Circular Progress Bar
The same project correctly works with my Galaxy Watch 6 Classic but not with a TicWatch Pro 5 Enduro: the progress bar doesn’t move at all, but the [HR] is correctly shown if used in a text field…
Some details:
Watch Face Studio 1.7.13
TicWatch Pro 5 Enduro with Wear OS 4.0
Have you tried ([HR]/2) . Some watches handle the syntax differently . Will your watch not update to WOS5 ?
Wow, this may be the solution, will try asap!
Unfortunately TicWatches are very slow with the updates, WOS4 is just arrived…
Many thanks for your suggestion, will be back soon :wink:
No way, even ([HR]/2) or [HR] alone did not solve the problem…
Really really weird, battery [BATT_PER] and steps [SC_PER] are working fine with progress bars, [HR] doesn’t
So does the HR show on other faces ? More specifically ones from the google store ? Looking at what you have shown us your MAX value should be 240 I think . But that will not necessary make it work . But of course if you are dividing by 2 that is different . I know it is silly but you could try (([HR])/2)
Make sure that your Face Has all the permissions for health data .
Hi Russel,
attached you can find a screenshot of the watchface, as you can see the HR value is correctly shown (so permissions should be ok)
, but the gauge around it “doesn’t move”, while the ones for battery and steps are working fine…
Is [HR] the value that’s sometimes returned as a string? If you, you need to use an expression to force the value to become a number. round() might work.
Wow, it worked! The “round” suggestion solved the problem
Thanks a lot Gondwana and Russel :blush:
I’m surprised too. :wink:
Brilliant . I always thought () made it into an intergern . I wish I could remember these things . Well done .
