IAP error E9202/6050: Product does not exist in this store
Hi,
I’ve just published my game to Galaxy Store and its ready for sale. My game developed by Unity and use IAP package of Unity to implement IAP.
I tried to purchase an item then I get error “E9202/6050: Product does not exist in this store”
I don’t know why I got this error. Please give me some advices!
Thank you!!
Screenshot_20201102-165949_Jewels Deluxe|225x500
Hello,
I downloaded your game from Galaxy Store (Jewels Deluxe - new jewels quest & classic match 3 free). When I try to remove Ads, I get a different error saying IAP has not been initialized. Few things to check:
  • Have you set IAP mode to production in the apk that you submitted to the store? Has IAP been initialized.
  • Please double check the item id you are using for starting a purchase.
Also, in order to improve the implementation and end user experience, we recommend to use:
Official Samsung IAP Unity plugin (https://developer.samsung.com/iap/samsung-iap-unity-plugin.html) as it supports the latest Samsung IAP 6.1
I saw the Play Protect pop up showing when trying to download your app. In this case, please submit an appeal to Google Play: https://support.google.com/googleplay/android-developer/answer/2992033?hl=en so your app is not flagged incorrectly.
Thank you,
Gaby
Few things to check: Have you set IAP mode to production in the apk that you submitted to the store? Has IAP been initialized. Pleaase double check the item id you are using for starting a purchase.
I am also trying to purchase the same remove ads thing but in Pakistan it is saying a different thing.
I asked my cousin in usa to check it said the Product not found
Product not found error is from USA and can no longer be purchased error is from Pakistan
It probably was suspended recent requirements updated the sellers to be DUNS verified and limit version supported by the app and so on. This thread is nearly 3 years old.
Ron
Samsung Developer Relations
