Hey all, your friendly neighborhood WFS design noob, here!
So I need a code (and a place to put it) that will make my SECOND hand complete a 15Hz SWEEP rotation once a second instead of once per minute. If I turn off APPLY ROTATION PROPERTIES, I found I can use a code in the ROTATE > ANGLE field, but can’t work out what needs to go there. I guess the parallel would be a millisecond sweep on a stopwatch.
Try to put [MSEC]*360/1000 in the field for tags. Theoretically this should work smooth, but in preview it just jumps around, the value of [MSEC] does not update fluently (at least not in my WFS).
People say that even on watches it moves jerky.
Yeh, that jumps all over like the [MSEC]*360/1000, does. Rats!
This just seems so strange, that they would not have a ‘complication’ for a subsecond stopwatch hand - that has been around for many decades, in the analog world.
It would maybe suffice, if they fixed how the [MSEC] tag updates. Even if you put it in a text field, it wont show fluently, but jumps trough about 5 numbers each second.
