Is the S Pen remote the same SDK for the S Pen?
Hi, I am trying to make use of the S pen from the tab like the tab S6 lite that I have, the problem is that I don’t know if the S Pen Remote it’s just for the Air Motions, how do you make use of the S Pen for example to draw or to write with it?
Hello Fritors,
You can utilize the x,y coordinate data from the S Pen Remote SDK. But you have to implement your own algorithm.
Thanks.
