How to get registered to partner level singing key?
Partner: These privileges can only be used by developers registered as partners on the Tizen store. The developer must be fully identified and permitted by the partner policy of the Tizen Store to use both public and partner level privileges.
I need this privilege which is throwing errors in config.xml.
To be a partner you need t go to the do this in the Smart TV Seller Office Being a partner is not extremely hard to sign up first you start out in a public group then a private group.
But that might not be an issue check the FAQ in the Smart TV portal there are several categories there so it may be in something not quite obvious.
Hope this helps.
Ron
Samsung Developer Relations
