I’m trying to setup a HTTP server on a Samsung Series 6 Smart TV. I downloaded the NaCL socket example from https://developer.samsung.com/smarttv/develop/extension-libraries/nacl/sample-based-tutorials/sockets-in-cplusplus.html, and added it to a Tizen native project.
I cannot get it working. There are no errors and the app just says “NaCL module status: uninitialized”. I would really like to try this, what do I do so that it loads it? I’m using a TV and not an emulator.
I also tried a different TCP socket example but while it loads I am not able to connect to the port (2601) from my machine to send data to the socket.
Finally, what is ecore_con server? Should I be using that over regular C sockets?
