Progress bar color jumped too much
Or both. As the progress bar first covers the edge(or curve) before doing the 1st percent. Why i do not know
@lebanoncedars
try this instead.
Progress bar with spaces_KNIGHT.zip (183.1 KB)
This looks way better than mine. But between the yellow and green has more space if u can see it than the others. and between the red and green is not aligned in the workspace area.
ok, thank you.
You seeing larger spaces
because
Changing cap style changes the lenght of the bar a little) so if done the way in my wfs
Expect green and yellow to be shorter.
And you have to
Play around with curving , or angular distance again.
To minimise changes just use left most (1st cap style)
For all.
Change red cap style to the most left (1st one also)
Take note on the yellow and green cap style.
And tag is [BATT_PER]
Max 34
Then realign to your liking
I fixed the 1% issue for you. Not redo everything if u know what i mean.
Or just leave it if for personal use:)
P.s my cap style i choosed for u was because i tought you like your progress bar to start with the “edge” (red cap style) but its easier to also start with the 1st one.
