Cool . Thank you . I use snipping tool .I will have another look at that . I am sorry the Images I posted above don’t show that well . I hope you can download them .
This is my snipping tool . which Windows are you using .
I use Windows 10
Petrin Natalino Giorgio
Mobile: +39 348 2932599
Fax: +39 049 8872650
Mail: giorgio.petrin@libeto.it
Mail: png.sanpaolo@gmail.com
You should not put so much Private info on this public Forum . Check your Spam Folder .
Hi, you are right, I made a mistake, thank you for the advice and thank you for the icons.
Cool you are Welcome . You can Edit your post . With your details . Just delete it .
