Questions about theme versions Android
Hi guys.
I have a question about the themes created GThemes Studio…
The themes are 2019 Android 9 and 2020 Android 10 respectively,
and Android 7 and 8? How do you make the themes compatible with
these versions? If there are any possibilities to do that.
When I used Android 7, had compatible themes in the store, Android 8 too.
But why are the themes I create today not compatible with old Android?
I didn’t find answers to my question anywhere…
Sorry for my english :confused:
I hope you understand…
:thinking:
Only 2 Android versions are supported. When a new version gets added an older one loses support.
Correct, no way with current tool to go back to “O” 2018 format…
But your question does raise a good point… I would love to see stats on which versions of my themes get downloaded. At this time, I have no clue if my old “O” version themes are still being downloaded, and how many “P” themes are being downloaded as well.
So i can’t add two versions?
Is recommend adding the older version, right?
Understand @Redacted
Thanks
Yes, you can load both “P” and “Q” binaries at the same time, just different version numbers
“M” & “O” OS is not more supported, if the the Theme Tool comes out for Android “R” then it will not more support Android “P”.
You can upload P and Q at the same time, also with same version numbers :wink:
