Remote test lab down?
Getting this error when trying to start since yesterday.
“Application can not be started.”
grafik
This is not infrequent with the remote test lab. There are several factors. A new one is if the connection is not fast enough it will reject the connection so be sure to select a close connection. For instance don’t try to connect to the US from Europe but use the Polish lab.
Another reason is that the last tester froze the mobile and it needs to be reset manually so on weekends this can cause several devices to be off line. It also could be a firewall issue.
If you are still having an issue. there is a contact us at the bottom of the RTL home page. Use that and report all information where you are located, what device you are trying to connect too and times. Screen shots of any error messages. I’ve found the RTL team to be very helpful and responsive.
Ron
Samsung Developer Program
It worked again on Monday, thanks.
it keeps giving me a 504 Gateway Time-out or a 502 Bad Gateway
No issue here in the States
The US device farm is offline so if you tried to access the US server directly you would get the error.
I get this error when in the Samsung Networks because the header it too long because of the Samsung 2 page sign on and redirection. If I open incognito or remove browser cache for the past week it opens fine. But again the US site has been offline for nearly 2 weeks.
While we banned some Domains that are primarily set up for SEO and other nefarious deeds as they were raising havoc with the RTL it was not your domain.
One of those should solve it.
Ron
Samsung Developer Relations
Today i’m trying to use, but I receive a loop of site, so, I can’t use!! 2 days ago i tried but there was the same problem.
@Dany_Brazil
They are rolling out some anti-malicious use measures and I think that is why It was down. I see some are available in Brazil now but nowhere the number there was last week.
I don’t usually check Brazil RTL so if it isn’t back to full numbers by Tuesday reply here to let me know.
Thanks for your patience,
Ron
Please ask RTL to upgrade newest devices to Android 13. I’ve gotten some themes rejections but there’s no way for me to test it. Thanks
@X9_Studio
They probably will be upgrading soon probably in Korea first. But consider this is a semi-manual process and not automated they are real devices.
Ron
when i log in to while trying t do remote test lab thing it says 403 forbidden
The RTL issue is a known issue you have to clear your cache for at least 2 weeks, I had to clear mine for a Month. What happens is the sign in verifies in Samsung.com and that adds data to the header and that is cached. But that isn’t removed from the browser cache so eventually the header gets just too long. Clear the cached and you should be OK. If not let me know I had to clear mine for 30 days.
Ron
When i go to Remotes Lab Device and click on “Get started button”, i’m getting this error
Hello
I did not check the Russian server but can you please check the following steps if this works for you.
  • 2 factor authentication is required to use Remote Test Lab service. Please activate 2 factor authentication of your account.
If you still face the problem after activating 2 factor authentication, please try the following:
  • Use the browser’s incognito mode to load the page.
  • Clear your browser’s cache if possible and try again.
If you get the same error message after checking this, then please let us know.
:slight_smile: thank you thank you
