Hi ssaha,
Thank you for your reply! I did check the sample projects, unfortunately none of these use the samsung-sap framework. Creating a Tizen 2.3.2 template in Tizen Studio allows for selection of samsung-sap and samsung-extension, however these do not show in Tizen 4.0 and Tizen 6.0. I have not checked version 3.0, as I had not installed that version yet. I did download the sample SAP projects from the aforementioned site, after which I imported one. It defaulted to Tizen 2.3.2 and showed the samsung-extension and samsung-sap frameworks activated. Strange thing is, I just now tried converting this sample project to Tizen 4.0, which gave an error (‘permission denied’), and now both samsung-extension and samsung-sap frameworks are gone from the list of that project. After clicking on build project for this, I get errors and the frameworks are NOT added back.
When building my own Tizen 2.3.2 project, I can select the samsung-extension and samsung-sap frameworks. When I then convert this to a Tizen 4.0 project, the frameworks disappear from the list and the app will give include errors for the sap.h file (and possibly more). After then converting this back to Tizen 2.3.2, the frameworks appear again, boxes being unchecked. Is the Samsung Accessory Protocol (SAP) just not supported at all above Tizen 2.3.2? I could try and develop my application in Tizen 2.3.2 although I’d rather use the version my own Galaxy Watch is at (4.0.7) than an extremely outdated version.
Thanks in advance for your reply and with kind regards,
Andreas
