I’m trying to set the battery percentage to a custom hand.
A small hand that ideally will rotate 0 to 60 degrees and maps to 0 to 100 of the battery.
I created a custom watch hand and set the sync-with to “Battery %”. I set the starting pivot angle and start points.
But the hand seems to rotate 360 degrees - I just want 60 degrees of movement.
I sort of stumbled upon a solution by setting the End Value to 500 - so it rotates 60 degrees now. Does that make sense?
Also trying to figure out how the Rotate Angle, Inner Pivot x/y are used -
Whats the difference between Rotate Angle and Rotate Properties Pivot Angle.
