Hi to all , In your opinion, to get an excellent output in Photoshop, how much should you first determine the size of the image? . And how much resolution should be set?
To what extent does this software support resolution? ( GWD ) . How much resolution is allowed? for (GWD)
Someone who knew Photoshop said you should enlarge the original size and increase the resolution of the photo and change the size to 360 from the output you got
To increase the image quality and reduce the problem in pixels
But I do not know what size and resolution to choose for the design
Finally, i wana convert the output photo to 360 size
Hello, sorry I can not advice much here. I guess it is good to make whole design at higher resolution, if not for the watch or GWS it self, then for the promotion images and then export smaller versions sized for the watch. The built in screen shots are taken in 512x512px and to me they look blurry due the up scale from 360x360.
I tried to insert images like double the resolution and then resize them in GWD, but could not see much difference in results on the watch screen. The watch and the program can handle even larger images. Yet I think inserting static images should be good in 1:1 resolution and save some MB of memory.
In old forum there was a discussion about it. For the rotating images like hands worked good if the inserted image was 1.3 times larger than the final size set in GWD for better anti-aliasing on angled contours.
I guess the dpi or ppi of images is for watch irrelevant, it defines how big would be the image when printed or displayed, main thing is to have at least one pixel of image for each pixel of the display.
Peter is correct. DPI or PPI are completely meaningless in a digital image file. All of these watches are 360x360, albeit round. I create all my images at 720x720 just in case they bump the resolution up to something higher in a future watch, or in case I want to recreate them for another watch altogether that has a higher res.
I will have to try some of these. It’s not easy to resize photos on your phone. Samsung has nice editing options, but they let you choose a few sizes only. I hate it the most when I want to post a photo on Instagram, and it’s not the right size. I looked for a solution for this problem for a long time, and I found it online. It turns out that you can go online and resize your photos the way you want them. You can find the right Instagram size, which I have been using the most. It makes my life easier because I don’t have to spend too much time on the size. I can just edit the photo the way I want.
