Wondering if I will need to delve into Tizen Studio for this, or if basic GWS tags can do this with effort:
Two different small images have their gyro properties which move their XY coordinates independently from each other. Can a tag scenario determine when the two images touch or cross each other?
Thanks Peter. There are tags for the position, for the X and Y values, though. I’m fishing for whether there’s a logic to compare the XY values of two different images.
Maybe I dont know the right words, I am not a programmer. The conditional expressions for comparing values can only compare variable values of tags.
If you define the x y placement coordinates fixed or with expressions, you can compare what you inserted there. To compare two variable values (tags) you have to put them in a formula (expression). But if there are no tags for gyro values, there cant be made an expressions to compare them.
An image’s Placement boxes for X and Y have scripting windows. What would be a reason to use scripting within these placement values?
Looking at the Tag Expressions tutorial, I don’t see any tag related to X or Y coordinates.
If I wanted the image to become visible only when the X value is between -10 and +10 then I might use the Opacity scripting window. Is there a way to do that?
