I am always impressed by the GWS in its ability to render properties without much code. But I am wondering if the problem is with my Active2 or if GWS doesn’t support opacity changes in both the seconds tags and in the gyro settings. I am wanting the Light_Effect to get brighter at each 0 seconds, and normal at all other seconds.
A Light_Effect by default has opacity settings within the gyro movement. When I add a tag expression in the Opacity setting so that the opacity changes at the [s]==0, the effect works well in GWS while previewing, but when I publish over to the Active2, the opacity is always stuck at that [s] ==0 value. I’ve restarted my watch and that didn’t fix the problem. I can only get the opacity tag expression to work if I remove the opacity setting changes within the gyro.
Even so, the result looks fine without the gyro opacity settings, but I am wondering what causes the discrepancy; too many calculations from too many sources is my guess, but the preview within GWS works, wondering why not on the watch?
