Can I change the style of the battery hand or step hand using handstyle presets?
Or can I use tag expression for hand propertys?
Thanks for your help in advance.
Hi, sure you can do both things. But the tags can not be used to change the color directly.
You can use theme for colour change. (apply it in the properties and then add themes in style tab)
To change colours properly, the source image should be neutral - white or in gray shades.
Thanks for the detailed information.
