Tizen Tv Automation
Hi, I need to develop a test automation for Tizen TV and perform UI automation for simulating remote control commands, Get the elements Id’s and perform click action.
I am able to get element Id’s using Web inspector by installing application on TV simulator available with Tizen Studio.
I got sample reference from https://samsung.github.io/Tizen.CircularUI/guide/CreatingTestAutomation.html for automating .Net Applications using C#, NUnit Framework in Visual Studio.
Below is the code I tried
  namespace TestTizen
   public class Class1
      private TizenDriver<AppiumWebElement> _driver;
      [SetUp]
      public void SetUp()
         Console.WriteLine("Connecting to Appium server");
         AppiumOptions option = new AppiumOptions();
         option.AddAdditionalCapability("platformName", "Tizen");
         option.AddAdditionalCapability("deviceName", "emulator-26101");
         option.AddAdditionalCapability("appPackage", "org.tizen.sample0008.Filesystem");
         _driver = new TizenDriver<AppiumWebElement>(new Uri("http://localhost:4723/wd/hub"), option);
    [Test]
    public void ClickAction()
        _driver.FindElementByXPath("//*[@id=\"info container\"]/div[2]/div[1]/div[1]/div[4]").Click();
The code has no errors but the connection with the Appium server is not getting established. It would be really helpful if anyone can help on how to execute the Test case.
Also please let me know if there is any way to make this possible with Robot Framework. Since, we primarily use Python and Robot Framework for Automation in our project.
Thanks in advance.
Is it possible to do Automation for Tizen TV?
Did you find any solution??
Hi, Please let us know, it is possible to do UI automation on TV platform or TV emulator.
