While I understand that on the higher end models it is possible to access the depth readings from the TOF cameras, I would like to know if it’s also possible to do so on the mid-range models such as the A50 and A51.
I tried using the 3D scanner app provided by Samsung and while it did install, it failed reporting that a range sensor was needed.
Since the A51 does in fact have a TOF sensor, is there some API that provides access to it?
