Trying to build watch face for Gear Fit2
Hi i am hoping to build a watch face for the GearFit2 but am unable to find software that will install on Windows 10. Is this now not a feature that is possible please?
Hi @sct73 ,
You can use the Galaxy Watch Designer (GWD) version 1.6.x or lower to develop watch face for Gear Fit2. See the Supported Tizen OS and Watches.
Azad
To add to azad’s response.
Be sure you have GEAR Fit 2, Galaxy Fit2 are “bricked” and can not be customized.
Ron
Samsung Developer Program
I have found that it is still possible by downloading the earlier versions of GWS
anyone knows if there is any app to design not only samsung watch faces?xiaomi for example. I got one as well and wondering if I could try to design a face for it same way as for the GearFit2
HI Andy,
There are several third party Watch Face design tools that run on both Samsung (Tizen OS) and on Android (Wear OS) smart watches.
Ron
