Using Tenzen CLI: Sign projects for TV
I have bought a “Samsung 77" S90D 4K OLED Smart TV (2024)” I am developer and I want to add a small WGT project to my TV. The tricky thing is that I do not have a UI available, so I can only use the Tenzen CLI to sign the project and all the guides are about the UI version.
My main goal is just to get my project installed on my own TV: so shortest path to that is great.
What I am thinking is:
  1. I need a Samsung distributor certificate?
    1. Or is it some other certificate I need?
  2. Then download that and use the CLI to generate a profile and package my project.
    1. I figured out how to use the CLI i am just missing the certificate. strong text
Hello,
For Smart TV questions, please log in to TV Seller Office: ( Seller2.0 ), go to the 1:1 Q&A section, and ask a question.
You can also find the local content manager.
Your Samsung Content Manager helps you manage various application development and distribution scenarios, such as permission to use partner-level privileges, removing application versions from distribution, and publishing an application in multiple countries or outside of the United States.
To request the contact information for your local Content Manager, you can request this information through the “1:1 Q&A” menu.
Thank you,
Samsung Developer Program Team
Seems like overkill?
I do not need to get the app to the app store: I just want to sign it so I can install it on my local TV.
