Using wakelock on TizenTV
I have a TV with Tizen, and I am trying to build a website and application for it
I have to ensure that while the website and application are working, that the TV will not go into sleep mode
I tried to use wakelock, but it doesn’t work
Which command should I use?
Since no one responded, I would suggest you look for an answer in the FAQ-Q/A under the most appropriate topic on the Smart TV Seller Office site If you don’t find a solution there then sign in and open a Smart TV Seller Support Request . They can help you better there.
Ron
Samsung Developer Relations
