Hello,
I have tested the customization editor feature. It’s working for me. You may check with a simple project and see if is it occurring or not.
You can create a support request along with a sample project if you think this is a bug.
Thank you.
Sadly no diffrences. Even with templates or a fresh created on (see vid).
Reinstallation doesn´t change anything.
After some “debugging”, I noticed that the error only happens when you right-click on the blank area on the left without having anything selected.
that means you can’t add entries (should you be able to do that with this tool? - unfortunately I don’t know much about it).
OS: Windows 11 Pro
Version 10.0.22621 Build 22621
Prozessor Intel(R) Core™ i7-10700K CPU @ 3.80GHz, 3801 MHz, 8 Kern(e), 16 logische(r) Prozessor(en)
BaseBoard-Produkt MPG Z490M GAMING EDGE WIFI (MS-7C76)
I could also duplicate this on Windows 10
Ron
Samsung Developer Relations
