1.7.9 Beta - Weather Forecast Temp Does Not Change between C and F
im new to the group. i am an retired ERP software implementation guy. I’m used to documenting and replicating an issue.
Been creating and publishing (thanks Tomas) a few faces catered toward people that want to monitor their Glucose and Insulin values.
Is this platform for reporting issues?
Ive spent the last couple days playing with the weather and forecast features. I have noticed that in the forecast weather temp does not change between scales (C & F).
Yes i can create an expression that will convert the values based on the temp setting. But when we display Temp on a Face it automatically changes between the 2 when we toggle it on the setting.
Please check the below thread:
Thank you for the response.
Your link has to do with the Weather tag. not the (forecastHours(2, “TEM”)) This TEM in the previous example does not change between C and F like the ([WTHR_TEM])
I have the same question… Only shows in C.
Hello, it changes on the watch. Seems it just the preview issue on the WFS.
Good to know, thanks.
([WTHR_TEM] > 0? ‘’: ‘’)[WTHR_TEM]°([WTHR_TEM_UNIT] == 1? ‘C’: ‘F’)
