Hi,
I would like to discuss an issue that I am currently facing with some of my apps. The specific problem revolves around the suspension of my apps for the reason of “Advertisement should not be executed.” I am using AdMob network.
I would greatly appreciate any assistance about this.
Thank you for your prompt attention and support.
Best regards,
Johana
I’ll contact you via the Developer Support channel.
Ron
Samsung Developer RElations
Hi,
Why I am not able to post concern in developer forum.?
There is a problem with the forum software that you have to create a new topic from the Forum Home page for a first time user it has to be in the general category.
I moved this to the Seller Portal / Android Apps folder I think you can now create one to that folder too.
First create a new Topic then you can select the category from the list at the top.
Ron
Samsung
