AOD time display problem
Hello!
I created a watch face with a hybrid time display in WFS for myself and found the following problem:
When switching to AOD mode, the digital time stops changing.
The analog time displayed by the hands shows everything correctly
If you activate the main mode, then everything is fine
For clarity, I took a picture of how it looks in two photos with a difference of 5 minutes
I will separately say that everything works fine in the designer, without problems
For creation, I used WFS version: 1.7.13
Samsung Galaxy Watch 6 Classic SM-R960
One UI 6.0 Watch
For time I used Digital Clock Variable separately for hours and minutes
Please tell me, maybe I made a mistake somewhere?
Maybe there is some solution to this problem?
I am attaching my file with the watch face
PV020_Copy.zip (485.1 KB)
Hello,
I think this has happened due to battery usage.
" the always-on watch face uses less power, there are limits to how much of an always-on display surface can be used. Samsung recommends a design that uses no more than 15% of the available pixels in always-on states. If your watch face uses significantly more than 15% of available pixels, it can be rejected.
For details check here: Always-on in Watch Face Studio | Samsung Developer
Thanks!
Thanks for the advice!
Probably the reason is energy saving
In AOD mode, the WFS designer shows:
Current On Pixel Ratio: 11% and this is within the standard indicator
But still, the digital time will not change
If anyone knows, tell me what to do?
At what stage does the energy efficiency control occur?
At the moment of conversion to the APK file or does the watch itself block these changes on the screen while this dial is working?
This is completely illogical! This spoils the whole attitude towards this watch, it is perceived as defective!
Why can’t I choose between battery life and AOD image myself?
Especially since all the indicators are normal
Is there a reason for using the variable (M) (M) for digital minutes? Maybe there is an issue with it in AOD mode. Instead, consider using the Digital Clock MM option. Alternatively, as I do, you could add a text field with the [MIN_Z] tag for minutes.
I really had to abandon variable(M)(M) and replace it with Digital Clock MM.
This option works
Greetings to all from the Homeland of the First Council!
sorry off topic. make i know how do you do the battery part on the progress bar that will fill up the red color according to the actual value of the battery %. same goes for the other side for the steps count.
