How to know what the API level is when you create a watchface?
When you press on the publish button a pop up will show the details information including the API level.
Default will be based on the OS of your watch. Those who are using GW 6 are in SDK 30 default. The default of the most updated studio is in SDK 30 if you’re not using any circular complications. It automatically upgrades to 33 and above for those who use the circle comp.
