This is my new watch face, and I’d like to ask: Is it possible to create a step counter, battery indicator, and heart rate monitor like this in Watch Face Studio? Are there any specific tutorials on how to do it? I can’t seem to find any guides online
For example, when the watch shows 78% battery, the hand also points to the 78% mark on the progress bar
Yes it is very possible. You put a Hand image in an image layer. Have the image pointing vertically and the centre of the image the pivot point of the hand. You need to wok out the maximum angle of travel and the angle of the start point. Then in the Rotation Field of the Image you have to scale the Variable for the motion of the hand.
So for the Battery hand it we would use.
270+[BATT_PER]/100*180
Give it a go see how you get on.
Here is my test Fake Zipped . Download it and Just delete .zip .
batt_hand_test.wfs.zip (542.8 KB)
Maybe not direct tutorials, but there were threads with this same topic, for example:
Thank you all so much for your help!
