There is currently a Bluetooth problem between the Bluetooth product and the Samsung smartphone, so please contact us.
Smartphone type
- Galaxy S20 ultra( Android 10, 11)-Bluetooth Issue
- Galaxy S10( Android 10)-Bluetooth Issue
- Galaxy S10 Note( Android10)-not Issue
- Galaxy S8 (Android9)-not Issue
Galaxy S20 ultra and Galaxy S10 operate normally after registering Bluetooth in the Bluetooth App.
However, if I turn off the app and turn it on, it won’t connect.
I tried initializing the network, clearing the Bluetooth cache, etc., but they are the same.
It works after rebooting and it does not work again.
If the app is a problem, it is questionable that the S10 Note should not be.
Do you have any idea what the problem is?
