Calls wrongfully categorized as "potential emergency call"
I am developing a CallRedirectionService and on my S22 (latest Android updates) dialing any number starting in “08” results in my redirection service being skipped.
I tracked this down to the NewOutgoingCallIntentBroadcaster checking the number for being a potential emergency call. “08” is one of the emergency call numbers listed in ETSI TS122.101 Section 10 but it should not be part of the emergency number list once a SIM-Card is present. This works flawlessly on a stock Android Pixel 6 Pro and a Nokia XR20, so there seems to be bug that is specific to the implementation by SAMSUNG (A customer running Android 12 on a Galaxy S10 complained as well).
Can you please investigate this and roll out a fix? This might break additional functionality for some users as well and produces very hard to track bugs.
Thank you for participating in the Samsung Developer Forum. However, this is not the correct forum for end product bug reports, questions or concerns. This forum is for 3rd party developer issues.
I would recommend you use the Samsung Members App for feedback
or
go to https://www.samsung.com and depending on your location
either → Click on Explore Tab → Click on Community
or
Scroll all the way down to the bottom of the page and under support is a link to the community
Because end user questions disrupt developer discussion this thread will be removed soon.
Ron
Samsung Developer Community
