Hello,
Is there a way to make the fonts to change color on tap without the use of expressions because when you use the weather complications expressions are disabled by default.
Hello,
Hello
Just create transparent fonts (digits if you want them for the digital clock) along with a black background or any background you want to use in the watch face.
You can do it in Photoshop or Gimp or any other text editor of your choice.
Import it in the watch face by selecting the appropriate function e.g. Digital clock
add the transparent fonts (by selecting bitmap fonts) add  a background color  and set it to tap to change .
Tap to change fonts have no connection with expressions and should work in a regular watch face and a weather watch face
Hope this helps
Thanks
Hello, thanks for the advise. I am having a bit of trouble though, for example i create the number 5 and i make it transparent, will i have to make the rest of the background some kind of solid color like black i guess? then make the same for all numbers. After i transfer them to GWS i will have to set a tap to change image behind the fonts but the problem is that the length of the time is not always the same, for example 14:44 is longer than 11:10 so sometimes the background behind them will get visible. Did i get it wrong? Did you mean another way of doing it?
Thanks in advance.
In the digital clock, in the properties section there will be two options at. Fonts or bitmap  choose bitmap add the transparent fonts you  created (in the 0 to 9 numerals )along with the colon in the symbol  selection
You will have to make to clock s one for 12 hr and the other  24hr and repeat  the same procedure for both
Then in the timeline look ot for 12/24 hr time right click activate and select the appropriate Digital  clock and hide the other one
That’s bit
Hello, it could help to make the black (or other background color) squares images with numbers of same width and so make the bitmap font somewhat monospaced.
Hi Malcolm_319
I read ur answer but from this words ( add a background color and set it to tap to change .
Tap to change fonts have no connection with expressions and should work in a regular watch face and a weather watch face ) i can not understand what u want to say.
could u explain what do u mean?
when I import every number and but it  in (bitmap font setting) and make it as button there is change image appears
Thank you
If you make a bitmap font as square images with transparent digits, then place one colorful image behind it, so the text layer above will work as a mask. That colorful image can be set as button and change to other images with different colors, gradients or patterns. It will be seen trough the transparent digits, which would seem like changing, while only the image behind changes.
Hi my friend
But you must know that
I have a main background to my watch face with a diff color and also I make it changable also …so the color of the bg of the digit will appear and be a baf design
That is true, with this method the digit “background” can’t be changed.
Hi
The only way to go about that is to create or make a cut out of the BG
and use the transparent fonts with a tap to change color under it
Then you will be able to achieve what you want
(changeable BG and Color fonts).
Try that
Malcolm
Hello Dear Friends
I am quite new here and I am wondering how it works , beacuse I prepared my own transparent digits and upload it to the GWS, so if the digits are transparent they are always transparent so how they can cut bcgk ?
thanks
Marcin
