But what happens is that I can’t remove the zip - Windows thinks it’s supposed to extract the files. Then I get res and those other ones. I can’t open it in WFS.
You just delete the .ZIP . Then it becomes a Standard .wfs . Nothing to do with Zipping or Unzipping
For some reason, I’m not connecting with this. So here we go again.
Wthr_Plus_Duo Bars.wfs.zip
Try sending it back to me and I’ll see what happens.
Don’t double-click the .zip. Right-click and see if you get an option to rename it. The F2 key might make the name editable too. Just remove the ‘.zip’ bit from the end of the filename, leaving something.wfs.
Are you copy and pasting the File name .
Ha Ha . I see you are only allowed to post the link once .
BIG_HEART_TEST.wfs.ZIP (209.6 KB)
I normally use the upload Button .
Was the file you are trying to post made on 1.8.7 . Is there a chance of confusion .
I would certainly Reboot your Laptop/PC .
No, it was made on 1.7.13. I think I’m done with this for tonight - will try again tomorrow. It just shouldn’t be this hard.
Yeah me to . Laptop is off. Somtimes strange stuff happens and there is no reason . ![]()
Has anyone found a solution for this? I am also facing this problem. All elements of this complication are disabled, it looks normal. No changes can be made to the pre-design that complication.
Which glitch are you having problems with? For the zip issue that nobody but me seems to have a problem with, I just save the file as compressed (zipped) - then it uploads fine.
For the edge complications, I just take out all the pieces except the progress bar. Then I make a separate group for step count and another for battery charge and battery %. See if this helps.
Duo_Basic_Wthr.zip (1.7 MB)
this one, Has anyone found a solution for this?
Which One ??? . We would all like to help .
Hi, to do something similar I used the wfs that Samsung included in the examples at the bottom of the WFS program. I’m attaching the original and my modification. I hope it can be useful as an example to use since I can’t get the DUO complication to work as I would like.
Purrstachio2Cat2.zip (1.4 MB)
Definitely another solution. Looks nice and is probably simpler than separate progress bar and groups as I did. Thanks.
@Hardiki have you tried using a default provider for each complication?
I did some of my own modifications to your modification ![]()
This one turned out to be quite fun. Life would have been much easier if the built-in ones worked better, but I learned a bunch of neat tricks.
Purrstachio2Cat001.zip (1.8 MB)
If you want to have fun try watching this WF I made.
I really like the WF you attached. Sorry, but I couldn’t quite translate your message - could figure out a little from my ancient knowledge of Spanish. I tried copying and pasting into Google Docs, with no luck.
