I would like to create a time based on the modified julian day parameter [g], but need to something like tag expressions to mathematically manipulate that numeric. Is this possible with GWS or would I need to use the Tizen Studio for something like this?
Hi @jonjaco,
What I have understood that you want to use [g] as something like a variable for your time. Correct me if I am wrong. In that case, your assumption is correct, you have to use Tizan Studio as it is not possible in GWS.
Azad
Thanks, Azad. That’s too bad. It would be an awesome feature if that were possible within the GWS environment.
