Is there a way, using tags, to have the seconds value separate the two digits, the left and the right, so as to have a different bitmap font for each segment of the seconds? In other words, how would I create this sort of look for seconds without creating 60 different images?
Update: sorry, wasn’t thinking. I would need an image with the opaque tag to show or not show based on the seconds, is all.
Hi @dlo1579881831,
I am not sure though, are you looking for something like below screenshot? Where you just need to set the ICU format as “ss” and add 10 bitmap images for 10 digits.
actually you would need 6 images for tens, another 10 for units all added as separate layers and set each layer to show or hide, in loop on time line or using expressions.
Thanks. Yes, I used tag expressions to hide or show the parts of the time. It is working well in the 12 Hour format which I use, but I will be adding the 24 hour format option as well, so I’ll need to add more duplicate images and hide or show according to the 12/24 format. Seems to add up with a lot of images!
