WIZCON
1
Settings / Notifications / Notifications pop-up style / Edge lighting style / Color
테마 적용 시, 체크 박스의 활성 또는 비활성 표시가 정상적으로 되지 않고 있습니다.
이것을 어떻게 해결할 수 있을까요?
Active or inactive checkboxes are not displayed correctly when you apply a theme you have authored.
How can I solve this problem?
I opened a ticket on this, but support no longer responds to tickets. It is a bug.
You have used images for your radio buttons.
For now all you can do is reset those images to default. The radio buttons will take color from primary, even though they show blue in the tool.
WIZCON
3
I solved it.
Thank you very much for the detailed information.
