Hi, I just got a theme rejected and I don’t know for sure what I’m supposed to change to fix it, visibility check on GTS couldn’t find the issue that has been reported. This is what I changed so far to see if it can fix the issue
Common> Color > “Primary Color”
Common> SmartTip> “Background Color”
This was the Review Result Report that I got before I did the changes I mentioned above:
I previously had the same issue, the short explanation is that it’s not your fault.
GTS does not provide enough previews for the UI (or at least this one in particular) but besides that, this is also some sort of a bug since this particular UI element uses the wrong color sources from the theme.
I have reported it through an iquiry, it will most likely be fixed in future versions of GTS (ETA: several weeks/months until it’s fixed)
This is why I wrote my own visibiltiy checker; it checks for all the rejections I’ve had that the tool doesn’t catch, but the Fold is still an issue. If I had the patience to learn how to package it I could ditribute it
