Hi,
I am currently struggling with a Tizen SDK Wearable Extension Error as I could not install it on Tizen’s package manager. I am currently using a Galaxy Watch 46mm with the Tizen version 5.5.0.2. The download URL zip file I found also does not seem to be working. I have already downloaded the Samsung Certificate Extension and the main SDK files for my wearable device but still cannot access nor download the Extension SDK for Wearable Extension from the Package Manager, stopping me from testing a downloaded application. How may I get around this and be able to download the needed SDK Wearable Extension? The error I received
are in the photos below. I would be grateful for any help, Thanks.
Are you using Windows 11? There is another thread that tells how to use Tizen Studio with Windows 11. I get the same error with my Windows 11 computer.
I haven’t tried the thread’s instructions. If You have Windows 11 I’ll give it a try and see if that makes any difference.
Ron
Samsung Developer Relations
I’m using Windows 10, still unsure on how to fix this issue.
Open a support Request in Samsung Developer Support. they should be able to check the site. I know Tizen changed their server not too long ago and maybe the redirect is not working.
Ron
