Hi, I am trying to implement gifting token function in samsung blockchain, which is like transferFrom in web3 smart contract. And as I found in the documentation, it seems there is no create intent for this smart contract, so could you help me with which API I can use for this function. Thank you so much!
Hello @yumizhtch ,
Thank you for your interest in the Samsung Blockchain Platform (SBP) SDK.
SBP SDK supports sending ERC 20 and ERC 721 tokens using the “transfer” function of a Smart Contract. You can learn more about how to create an intent for ERC20 and ERC721 transfer from the programming guide.
PS: If you find this answer helpful please press the “like” button so that others can find it more easily.
Best Regards,
Shuvo
Samsung Developer Program
Thank you so much for getting back to me. Solve my problem perfectly!
The ethers.js library aims to be a complete and compact library for interacting with the Ethereum Blockchain and its ecosystem. It was originally designed for use with ethers.io ethers and has since expanded into a more general-purpose library.
